josephf31 | Help me with my top! separating from frame | ||
Hey all! Hope you can help with this problem.
On my 1991 C4 coupe, the smoke colored top has separated from the (metal?) frame across most of the front. Is this something I can easily repair or is it easier/better to bring it to a place like a glass repair shop? I did some checking and found that a product called Weld-On # 10 may do the trick, has anyone had any experiences, good or bad, with this or any other product? Thanks!!! |
Posted on: 2009/3/7 21:48
2002 Magnetic Red C5 6 spd LS1 convertible |
bogus | Re: Help me with my top! separating from frame | ||
I would say it's time for a new top or a total reconditioning... once the glue gives, it needs to be replaced entirely.
I would find a good glass shop and see what they say. As I understand it, the tops are made under pressure. The lexan is pressed onto the top frame, with the glue in the middle. The glue sets under tension. BTW, if anyone knows other details, please correct or share. I got this info from a Corvette specialty house. |
Posted on: 2009/3/7 23:58
Midnight85 | Re: Help me with my top! separating from frame | ||
You are right on about how they do it, I watched one being done when I picked my new one up at Melrose. You are also correct that it isn't worth the hassle trying to find something that will hold the top together. I tried 3 times before getting a new one. To the OP, get a Melrose, stay far away from Astro |
Posted on: 2009/3/8 1:19
HORSEPOWER! Some is good, more is better, too much is just right. |
josephf31 | Re: Help me with my top! separating from frame | ||
Thanks all got some more questions; How much is new top? Is it safe to get a refurbished one? What's so bad about Astro? Where do I find Melrose Thanks again! |
Posted on: 2009/3/8 2:23
Astro's suck. It's that simple. I have never heard of one lasting more than about 18 months. Seriously.
Melrose? I don't know specifically. This is their site: http://www.melroset-tops.com/ You can get a refurb... but the key is prep. Melrose does refurbs, if anyone is gonna do it right, it would be them. A new top is about $500.00 or so. |
Posted on: 2009/3/8 2:48
Give Jay a call at Vette2Vette, 815 673-6200. If he hasn't sold them he has a couple nice ones.
Posted on: 2009/3/8 4:48
Yup I know Jay have already bought quite a bit of stuff from them, was planning on calling him anyway. Anyone have any experience with this place?; http://www.corvettettops.com/84-96.htm Also in researching this I have found that maybe marine adhesive/sealant will work? If I can fix this without having to spend $500 to $1000 for a top I'd really like to... thanks again all |
Posted on: 2009/3/8 21:19
I just don't think fixing the problem will be enough. Once the glue fails, it will continue to fail. It's like a zipper now and nothing will stop it. Remember the tension issue.
You might be able to play with the insurance company. If you have glass replacement, that is. My 92 got hit in a hail storm in April 2002. State Farm bought me a new top. |
Posted on: 2009/3/8 21:48
Randyj75 | Re: Help me with my top! separating from frame | ||
My top developed a crack, and my insurance co. (State Farm) paid to replace it. Melrose will redo you top for $595.00. Good deal.
Randy |
Posted on: 2009/3/9 1:23
'90 Corvette, M6,a few mods, more to come |
Marine epoxy is just one of the adhesives I tried and if memory serves me correctly it failed faster than the other two products. I realize it is a big cash outlay but I know of no one who has successfully re-attached their top. Give this some thought, if your top flies off at speed and happens to hit another car causing an accident, you could be in big trouble. There are many things you just can't shortcut on, this is one. |
Posted on: 2009/3/9 1:49
Well looks like I'll have to bite the bullet on this one and spring for a new (or maybe used, but vette2vette has none) top...the good thing is I just got my tax refund! How much does a Melrose top run, about, anybody know? and for the 'core charges' will they (Melrose, etc.) "deduct" for a core that is separating from the frame, but not cracked? thanks again all |
Posted on: 2009/3/9 2:10
Melrose doesn't care about condition. All they want is the frame.
You see, on a reman, they put new glass on an old frame and add seals. So separated... cracked... it don't matter. As long as the frame is ok, you are ok. |
Posted on: 2009/3/9 3:54
THX138 | Re: Help me with my top! separating from frame | ||
A friend had a glass shop come out and fixed his.If the top you have now is the original top for the car it will have the VIN number etched on the frame,might want to keep it and not turn it in for a core if you do get a replacement.
Posted on: 2009/3/9 4:58
