300 user(s) are online (263 user(s) are browsing Forums)
Also known as the DIC.
happydad Whine in my 3:73 Diff
northern Ill
151 Posts
Hi Guru's...The rear pinion seal was leaking this winter and I have yet to replace it(Lazy)..But I did take it around the block for a shake down cruise and heard a whineing noise coming from the rear...Also heard a thumping like noise(off and On,Not real Loud) coming from back there also...I guess it's time to replace the seal and refill Huh?? Although the leak did'nt seem that bad..The rear has been rebuilt and should have had the proper amount of fluid(although I did not install it)..What do you guy's think
Posted on: 2009/3/16 11:12
bogus Re: Whine in my 3:73 Diff
3.73 in what? D44 or D36?
It also depends on the source of the gears... some are prone to whining.
It also makes me wonder if the shop set the gears right in the first place.
The on/off thumping noise makes me think LSD (diff, not narcotic).
Posted on: 2009/3/16 13:36
happydad Re: Whine in my 3:73 Diff
northern Ill
151 Posts
D36...Will Change Seal and fill...I kinda think The SoB Did'nt Change all the U joints....
Posted on: 2009/3/16 23:27
CentralCoaster Re: Whine in my 3:73 Diff
It shouldn't be making any noise other than maybe a gear whine, low fluid or otherwise.
Posted on: 2009/3/17 4:14
northern Ill
151 Posts
It must be just the gears..Fluid is fine..Ujionts look new..Prolly not used to the gears yet..Thanks for your thoughts..I Freaked for a moment..Don't need anything else to go wrong
Posted on: 2009/3/17 10:34
anesthes Re: Whine in my 3:73 Diff
Boston, MA
Did the pinion nut back off?
Posted on: 2009/3/17 10:36
northern Ill
151 Posts
Thanks I'll check that
Posted on: 2009/3/17 22:54
85L98-84L83 Re: Whine in my 3:73 Diff
113 Posts
Screw the whining sound how is the off the line performance?
Does it peal the rubber off the tires?
Posted on: 2009/3/18 12:21
CFI-EFI Re: Whine in my 3:73 Diff
Top of Utah
372 Posts
Helpful, as usual.
RACE ON!!!
Posted on: 2009/3/18 14:28
