162 user(s) are online (124 user(s) are browsing Forums)
iCorvette how do you fix a seat belt retractor that gets tighter and tighter
302 Posts
on my drivers side, like a boa constrictor.....
Posted on: 2009/9/6 17:30
bogus Re: how do you fix a seat belt retractor that gets tighter and tighter
20856 Posts
yea... know the problem.
take the retrator wheel out of the floor/lower rocker. Remove the plastic coverings and blast the damned thing clean with compressed air. Fuzz, hair, dust, coins, straw wrappers... you name it, gets caught up in there and really screws it up.
It is a very basic mechanism, you just need to be 100% sure it is clean.
Posted on: 2009/9/6 18:26
iCorvette Re: how do you fix a seat belt retractor that gets tighter and tighter
302 Posts
what is the procedure to access the mechanism, remover seat? sill protector?
Posted on: 2009/9/6 19:17
20856 Posts
easy - move the seat all the way forward, remove big ass torx bolt, remove plastic cover.
So easy you are saying "d'oh!" right about now.
Posted on: 2009/9/6 22:06
302 Posts
thanks it is improved 80%, didn't go away but i think it suppose to cinch in spirited driving...
as far as simple mechanism i don't think so, seem like alot is linked to each other to behave in a certain manner, regardless it was not that dirty, an accumulation, of dust bunnies, compacted, but i cleaned it out as best as i could, no compressed air, just lungs...
thanks bogus who needs cf?
anyone is smart they should advertise here and not get lost in the clutter, it would stand out and enough of the serious folk come here anyhow....
Posted on: 2009/9/7 2:09
20856 Posts
Glad I could help! There is a simple intertia takeup with a counterweight to keep it under control. It will tighten during drive if you activate the intertia counterweight.
I started on CF 9 years ago... got shit-canned Dec 2007. Apparently, they are more concerned with behaving than with actual knowledge... oh, well. We got ours, right!?!?!
CentralCoaster, JeffVette and Notorious all got burned at the same time. This place has become CF without all the politics and the attitude... also, we have the right answers!
Posted on: 2009/9/7 3:45
302 Posts
i got burned for a week, my fault and then a month for defending myself from antagonistic losers, long to short, is if you get the answer in one response, who needs 75 which would include irrelevant or inaccurate diagnosis.
Posted on: 2009/9/7 8:37
20856 Posts
God forbid you defend yourself over there... I hate the mentality that has taken over.
Such a shame...
Posted on: 2009/9/7 14:09
Randyj75 Re: how do you fix a seat belt retractor that gets tighter and tighter
MD
129 Posts
One thing to keep in mind is that at some point, there was a factory recall on the seat belts. Try calling a dealer near you and tell them of your problem. It could be that your car was never fixed, and the dealer will replace the seat belt for nothing.
Randy
Posted on: 2009/9/12 20:34
302 Posts
no more parts....
Posted on: 2009/9/12 21:38
20856 Posts
Didn't think so... that recall ended years ago!
Posted on: 2009/9/13 2:48
302 Posts
didn't think they would establish an end date on something like that, the cinching has improved but did not go away... oh well
Posted on: 2009/9/13 2:58
20856 Posts
the thing is, all recalls do time out... and not all cars qualified. It is a range of VINs... I have no clue if your car qualified.
Posted on: 2009/9/13 3:21
jhammons01 Re: how do you fix a seat belt retractor that gets tighter and tighter
Yeah...but from a legal standpoint.....not one Manufacturer would turn you away with a seat belt issue......
Push that button and see where it takes you..
One time with a Nissan retracting deal on the door.....it was broken so I took it to the Dealer to be fixed. They quoted some outrages price to fix it......I told them to put it back together and leave it alone....
....when I went to get it from them....the thing was fixed and everyone was sorta quiet as to why it was fixed at no charge......
Posted on: 2009/9/16 14:51
lunytnz Re: how do you fix a seat belt retractor that gets tighter and tighter
46 Posts
Even though this post has been around for 10 years, it was helpful to me in removing the seat belt assembly.
It's a T-45 torx bolt, BTW. And it took a LONG time because I only got 1 click on the ratchet with the limited space behind the seat. AND... it got a lot tougher to turn when the bolt was nearly out.
Posted on: 2019/5/11 16:38
20856 Posts
I noticed that! Good old days... before facebook took everyone.
I think the captive nut is pinched, making it tighter as it goes.
Posted on: 2019/5/15 2:25
