| Steve40th | Dana 44 Rebuild, any suggestions? | ||
After extensive datalogging, and the tuner working to tweak my engine a little, I decided to look at the underside.
Well, U Joints are solid, spicers from about 3000 miles ago. They were the proper ones everyone recommended on many forums. Anyways, I moved the wheels back and forth while I had the car in neutral. The diff is definitely clanking. I recorded it with the phone. hard to tell but, with hand on diff, or a screwdriver, I can here allot of metal clanking. Not sure what would be wrong in the D44, but it was rebuilt with new gears by Ikerds before he passed in early 2000's. Its seen its fair share of drag racing in Hawaii, but nothing since it shut down in 2005 and or since I have been back on mainland, in 2012. Just need a recommendation of a rebuilder, or one laying around. I have 3.33 gears, used. Just looking at options. In all honesty, 3.73 are too much for the 396LT1. Lots of rpms at 80mph.. |
Posted on: 2022/7/7 21:10
Ko'u ohana aia ku'a ikaika |
Transfer
| Eagle223usa | Re: Dana 44 Rebuild, any suggestions? | ||
Guru with Eyes of Steel
Did you pull the rear cover and check it out?
Posted on: 2022/8/4 17:17
God Bless America! |
Transfer
| Steve40th | Re: Dana 44 Rebuild, any suggestions? | ||
Still not home yet. I went under and did some more checks. Its damn tight.. As soon as I turn the wheel, the pinion/driveshaft moves. When you move wheel back and forth fast you hear the clunking, as if the gears are going from front to back of teeth, if that makes sense.
The ticking I hear is rear of transmission in tail shaft of 700R4.. I will be back in a couple weeks, and if weather permits I will dig further into it. Right now, not 100% sure WTH is clunking. I would think big cam, and car barely on idle cruising is causing it. |
Posted on: 2022/8/4 17:45
Transfer
I would pull the drive shaft and check the diff for slop independently. I guess everyone is hanging out on F book these days...
Posted on: 2022/8/6 17:41
Transfer
I could check it again. It was out about 2 years ago when the Donut came off.
Posted on: 2022/8/6 19:15
Transfer
| bogus | Re: Dana 44 Rebuild, any suggestions? | ||
used gears are always a gamble.
Never know the wear points. |
Posted on: 2022/8/12 23:02
Transfer
Yep. Just got back. List of repairs, dishwasher just crapped out, and other things may take a few days.
I need a person to take care of my house when gone.. Clean, outside of home. All I have is a cat sitter, and yard guy. Car is not on priority right now. Within a few days I will get to it. |
Posted on: 2022/8/13 0:15
Transfer
cars can take the back seat... especially when a cat needs cared for!
Posted on: 2022/8/16 19:19
Transfer
Darn right. She is a 16 year old out door cat, that decided this year she was moving in. Wont even step foot outside.
Hawaiian cats( we brought her back from Hawaii), I tell ya. |
Posted on: 2022/8/16 19:40
Transfer
Do Hawaiian cats hang looser than others?
Posted on: 2022/8/17 18:05
Transfer
Hawaiian cats just hang, they are very laid back.
Posted on: 2022/8/17 18:26
Transfer
awe, so cute!
Posted on: 2022/8/18 21:19
Transfer
Transfer
