114 user(s) are online (69 user(s) are browsing Forums)
KeyWestJack Noise when starting out
25 Posts
I recently purchased a 90 convertable L98 auto trans. One of the previous owners eliminated the FX3 option with standard shocks. The connectors are taped in the front (no acuators). When I start out with the car after start up and drive off for several feet (either reverse or forward) I hear a growning noise from the rear then it goes away (matter of a few seconds). Am I hearing the remenants of the FX3 or something else? Thanks for the input. Jack
Posted on: 2006/9/29 15:17
freakd RE:Noise when starting out
727 Posts
hmm, i dunno, where's bogus, he would know about this better
Posted on: 2006/9/29 17:50
brut RE:Noise when starting out
New Albany, IN
1308 Posts
ABS system located in the compartment behind your seat. They all do it.
Posted on: 2006/9/29 19:56
KeyWestJack RE:Noise when starting out
25 Posts
Good to know! Thank you!!!
Posted on: 2006/9/29 20:53
727 Posts
i'm so used to it i forgot about it
Posted on: 2006/9/29 22:24
red_johnny RE:Noise when starting out
Hmm, glad I got an 85 then
Posted on: 2006/9/29 22:54
