| astock165 | New rear spring mount based on low friction pin top shock mounts | ||
We recently received our first shipment of a new, low friction, rear spring mount that is based on the same Delrin and stainless steel design as the pintop shock mounts we distribute from Hardbar. This mount allows free movement of the stock transverse rear leaf spring while removing the rubber or poly bushings usually used that can mask the real rate of the spring. They can be used with any stock or aftermarket spring bolt up to 9/16" or 14 mm diameter.
Below are some pics of the kit but more information on this new product can be found on our website. Retail price is $70 and they can be purchased directly at our online store. Contents of the kit: ![]() Shown here with spring bolt (bolts not included): ![]() close up of the bolt head and the kit: ![]() |
Posted on: 2011/3/19 21:17
Banski MotorSports LLC Manchester NH tom@banskimotorsports.com www.banskimotorsports.com |
Transfer
| astock165 | Re: New rear spring mount based on low friction pin top shock mounts | ||
We've revamped the kit a little to reduce the price and enable the kit to be used with the stock style and most aftermarket bolt springs on the market. I've updated the OP.
If you have any questions be sure to ask! |
Posted on: 2011/7/20 23:50
Transfer
Transfer
