695 user(s) are online (338 user(s) are browsing Forums)
rklessdriver 427 SBC parts
I am parting out whats left of of my old 427 SBC out of my 84 Corvette Real Street class car.
This engine orginally came from Nyes Automotive... Dyno sheets show 601hp@6400RPM. I bought the car with this engine in it - sight unseen, made minor induction changes and raced it for a year with no problems. Car ran mid 10's@125 mph in the 1/4 mile on pump gas and 9.30's@146 mph on an 82N jet (about 200HP nitrous)on VP C12 racing gas. FYI this is a 3120lb stock suspension 84 Corvette. Best of 6.02@112mph to the 1/8th mile.
Parts are in very good condition unless noted otherwise.
Complete internally balanced rotating assembly. Will be glad to provide PN's to serious potential buyers.
Eagle 4340 forged Crankshaft. 4" stroke
Eagle 4340 H Beam Rods. ARP 8740 bolts. 6" length
JE 4.125 bore 1" compression height flat top pistons. 10.7 SCR with 72cc chamber cyl heads. 1/16. 1/16. 3/16 ring lands.
$1000.00 rotating assy - AS IS.
Full discoloure. The crank needs to be turned 10/10 to be perfect... it was never hurt but upon teardown inspection it was found to have a 2-3 tenths of taper in every journal... Typical Eagle on a bad day. I didn't build it orginally but aparantly that's what passes for good spec with some engine builders... I orginally planned on reusing this crank in my new 434 and while a 10/10 crank is fine for 99% of things - it's just not suitable at 1,100+HP.
I will be glad to fix the crank and supply the buyer with new King HP brgs and Perfect Circle file fit rings giving them a ready to assemble rotating assy. Guaranteed it will be 100% right when you get it from me.
$1500.00 rotating assy w/crank turned and new brgs/rings.
Dart Pro 1 230 Alum cyl heads. 72cc chamber. Box stock unported. Erson ClyAlloy .700 lift mech roller valve springs. Stainless steel 2.08 intake valves and 1.6 exhaust. ARP 7/16 studs and Comp Cams guide plates. Harland Sharp 7/16 1.5 ratio roller rockers. PRP stud Girdles. Erson/PBM 5/16 .080 wall psuhrods.
$1200.00 for heads and everything else in the top end.
Comp Cams PN 12-970-8 "312R" Solid roller camshaft.
312/3252.020
279.286@.050
.679/.645 lift w/1.5 rockers
108 lobe centers
Erson/PBM solid roller lifters. .842 dia .300 tall vertical link bars.
$250.00 for the Roller Cam and Roller Lifters.
Moroso PN 20195 oil pan. 8" deep clears 4.125 stroke. Includes Moroso dip stick kit, Melling M55HV oil pump and Moroso pickup tube.
$175.00 for the OP, DS, OP, PU.
Professional Products Hurricane Single Plane Intake. PN 5231. Box stock unported.
$125.00 for the intake manifold.
Any questions PM me.
Parts are located in Hampton GA. You pick up in person or pay shipping.
Thanks
Posted on: 2013/12/9 21:34
