262 user(s) are online (208 user(s) are browsing Forums)
freakd leak
727 Posts
Posted on: 2006/7/29 16:17
freakd RE:leak
727 Posts
looks like fun to replace the thermostat
Posted on: 2006/7/29 16:25
freakd RE:leak
727 Posts
i wiped it down, put fresh anti-froze in it, and went for a spin, pullled over a couple times and checked stuff, the fan isn't working, it was caught up on the shroud somehow, so i think the motor is gone
Posted on: 2006/7/29 19:55
freakd RE:leak
727 Posts
it's free wheeling now, but it wasn't, i let the temp go to 240 before i closed the hood and took off and got some air to it
Posted on: 2006/7/29 19:59
brut RE:leak
New Albany, IN
1308 Posts
Sounds like you got some quirks to work out. Is the shroud bolted securely?
Posted on: 2006/7/29 23:39
freakd RE:leak
727 Posts
yeah, i think the fan motor is shot, when i fist pulled on it the engine was going, it felt like it was hung up, i'm almost certian it's the motor, gut feeling
Posted on: 2006/7/29 23:49
freakd RE:leak
727 Posts
there is a leak at the thermostat housing, it's a bad seal. the fan motor is shot
i had the car hooked up to a computer, maf is fine, o2 sensor is fine. fan not coming on, so we went and found the relay, which was broken and barely together. off of that we found a fuseable link, blown. we bypassed it, and the fan turned, slowly, and was drawing amps like mad, so bad motor. looks like when my parts get here, i'll be busy. i hope i can get this all done before carlisle, i hate to take the truck there
Posted on: 2006/7/31 14:59
freakd RE:leak
727 Posts
i was charged $10 to find all that out :thumbright:
Posted on: 2006/7/31 15:17
CasetheCorvetteman RE:leak
Im not familiar with what youd normally pay for that kind of diagnostic work, but $10 USD sounds like "mates rates" to me!! I dont think you could ever get such a bargain anywhere else!!!
Posted on: 2006/8/3 2:16
