239 user(s) are online (204 user(s) are browsing Forums)
freakd so 10 years ago
727 Posts
the top of the engine was rebuilt, i'm starting to think that the top part is now leaking, not a good thing. i know the plenum and intake were off the vehicle. is it possible that it could be leaking, and what are the consequences. i'm going to my mechanic tomorrow to verify this, and my fan motor., if it is bad, then the car goes up, until i can afford to rebuild the engine. if this happens, i want to rebuild it so i can run a superram
Posted on: 2006/7/30 19:12
brut RE:so 10 years ago
New Albany, IN
1308 Posts
When you say "top" do you mean heads, cam, and so forth?
Posted on: 2006/7/30 19:24
freakd RE:so 10 years ago
727 Posts
where the intake is :thumbright:
Posted on: 2006/7/30 19:31
New Albany, IN
1308 Posts
So just the plenum, fuel rails, injectors, manifold and runners were removed?
If it was ten years ago, depending on what they used for gaskets, they could verty well be shot especially if everything wasn't tourqed down to specs.
If you are debating doing the Superram swap, its getting close to being a good time to do it, during the winter(if you have a heated garage). Plus, if you are not wanting to buy new, I am sure they will be coming available soon on CF due t o people's winter projects.
Posted on: 2006/7/30 20:55
727 Posts
ok,i took a light and stated digging, doesn't look bad, there appears to be no water in my oil and no oil in the anti froze, whew, which is a relief. the original leak appears to have stopped, after i filled up the surge tank to where it needed to be, but i am still taking it to my mechanic tomorrow
Posted on: 2006/7/30 21:24
