212 user(s) are online (111 user(s) are browsing Forums)
freakd i got some new parts
727 Posts
so, i have a new throttlebody gasket, a new thermostate,and gasket for the housing, a new fusable link for the re;ay to the fan motor, a new fan motor, and new brake pads, all i need is the rotors. i also have to replace the damned ribbon for the drivers side powerwindow, and get in the new antenna motor, anyone wanna help??? :thumbright:
Posted on: 2006/8/3 21:29
brut RE:i got some new parts
New Albany, IN
1308 Posts
Sounds like you a have some wekeend projects ahead of you!! I took the attenna out of mineand it wasn't bad, but it wasn't fun either. You know what you COULD do? Take some pictures of it as you do it and the thermostat and make some tech tips for us!!!
Posted on: 2006/8/3 21:41
freakd RE:i got some new parts
727 Posts
i was planning on it :thumbright:
Posted on: 2006/8/3 21:56
CasetheCorvetteman RE:i got some new parts
Yeah mate, ill come over and give you a hand for sure. Ill bring the scotch, you pay for the travel
Posted on: 2006/8/4 14:00
