218 user(s) are online (184 user(s) are browsing Forums)
-=Jeff=- Stage 1 System install idea/questions>>
Bartlett, IL
573 Posts
so my 90 has the stock Blose system
Cd player is non-functioning. with everything else I need to do I was thinking of swapping in my Nakamichi headunit but where do I need to interface it to the Blose amps? at the CDM?
The other thought is to fix the Bose CD unit.
My aftermarket system has a Nakamichi CD400, eD NINe.5 eD 9kv.2 and some CDt front speakers. that will probably get installed later this year..
any thoughts for a temp solution for the CD? repair the CD at $120 or install the Nak?
Posted on: 2008/1/12 6:03
-=Jeff=-
1990 Corvette ZR-1 #1051
bogus RE:Stage 1 System install idea/questions>>
gee... this is a good question.
My opinion, flat out, is to gut the ENTIRE Bose system, or do nothing at all.
You have the hardware, so it's not like you are waiting to save up to buy more parts.
For example, to interface the bose to the Nak, you will need adaptors, which cost money... money that will go down the drain in 30 minutes when you gut it out...
just seems to not make any sense.
Remove it all. Put it in a box and get to building stuff.
Then again, this is in the Z, so I would want to keep that thing 100% stock... just my opinion...
Posted on: 2008/1/12 19:56
-=Jeff=- RE:Stage 1 System install idea/questions>>
Bartlett, IL
573 Posts
c'mon Bogus, you know I can't keep it stock.. LOL.
the ZR-1 as I got it, needed and still needs TLC. The interior is no longer exactly stock (colors have changed). anyway if I do an aftermarket system I will make it so going back to stock is still possible.
I guess I agree on not doing anything but I do think I will send the Cd unit out to be fixed, that way it is in working condition. The aftermarket system will go int he car.
The 89 will hopefully get sold this year and I want to enjoy the Z when I drive it.
so maybe getting the CD unit fixed is a good idea whether I use it now or not..
Posted on: 2008/1/12 20:05
-=Jeff=-
