255 user(s) are online (234 user(s) are browsing Forums)
freakd ok, antenna motor replacement help needed
727 Posts
seriously, on my 87, the 2 bezel nuts are welded together, it seems, i just can't get them apart!!! any easy way to do this, without hurting the car??? i'm taking the new motor to carlisle on the off chance i could get some help. let me tell you, this is driving mne nuts.
so when i turn the nuts, the whole motor turs, which means the antenna mmast is tight in the bezel nuts. if i unbolt the motor from the frame, and pull down on it, bringing the mast down. will this release enough pressure on the nuts to let them seperate???
any help is much appreciated :thumbright:
Posted on: 2006/8/15 15:50
bogus RE:ok, antenna motor replacement help needed
you mean the nut that holds the antenna to the body?
wow... have you hit the area with some PB Blaster?
Posted on: 2006/8/15 18:05
freakd RE:ok, antenna motor replacement help needed
727 Posts
no, not yet :silent:
Posted on: 2006/8/15 21:37
727 Posts
even if i do that, i'm not sure how to get a wrench on the nut
Posted on: 2006/8/15 21:45
there is a special socket for that nut.
need one?
Posted on: 2006/8/16 4:22
727 Posts
you got one??? i could use it, you still have my info??
Posted on: 2006/8/16 12:57
sure... I will send it....
go ahead and resend me your address info...
Posted on: 2006/8/17 5:15
