ChevysRUL | 1990 Job Number | ||
Does anyone know where (if) GM stamped or otherwise put the Job Number on the C4s. I have a C5 as well and I found the job number on that. I just was wondering if it was on the car somewhere I can retrieve it.
Thanks. |
Posted on: 2008/1/22 22:04
1990 Red ZR-1 1999 Pewter Coupe 2000 Dodge Dakota 4x4 |
joeld | RE:1990 Job Number | ||
Do you have the window sticker for the car? If I'm not mistaked the build sequence number is in the top right corner just under the VIN number. This should be a 5-7 digit number depending on when car was built. If not sometimes a build sheet was left in the car from an employe installing seats(under side cushion), possibly stuffed up in the dah area, or under the carpet. Sometimes the build number was hand written on the inside of bumpers, gas tank, under console for purpose of scheduling.
Joel |
Posted on: 2008/1/23 1:32
1989 Coupe,L98 automatic |
