C4Williams | C4, front mask is off, i need to get the checkerboard front piece off. | ||
When the Front bumper MASK is off there is a checker board looking plastic piece that the fog lights fit in, i need to remove it. there was 8 12mm i belive but there is some little screws that look like allen wrenches.
I tried to get a fit but i am missing something if anyone can give me the steps or some advice on this removal process i would appreciate it Thanks |
Posted on: 2011/11/29 4:11
bogus | Re: C4, front mask is off, i need to get the checkerboard front piece off. | ||
Well, I don't know why you need to remove the bumper honeycomb, but you will more than likely need what is called a torx socket to do it.
Sears has a very nice set, with life time warrantee, for about $40.00. It will have all the torx you will ever need. If you look at one, it looks like a star, much like the asterisk - * |
Posted on: 2011/11/29 4:47
C4Williams | Re: C4, front mask is off, i need to get the checkerboard front piece off. | ||
Inside the slots i have cleaned out good but from what i see you cant get the fog lights out unless it comes off. i want to clean them as good as possible
Posted on: 2011/11/29 16:15
Do you have the factory service manual yet? This is an 87, right?
Posted on: 2011/11/29 17:01
I found a Thread on CorvetteF. that you can get the fog lights out without the removal of Honeycomb. i am gonna try that first. but i will keep you posted.
I do have a manual. 1985 |
Posted on: 2011/11/29 17:38
ah, ok.
I have never tried to remove those bits... they are so fiddly going back on. A lurking guru, alcee1, has an 84. He redid his fogs with clear lenses. Took off the oem lenses and put on clear pieces. Too a while, he said, but the end result is impressive. |
Posted on: 2011/11/30 1:23
i would love to know how he got to the bolt that holds it on.
One side of the Light you can pull and its free, but the other side you can see the bolt that is mounted. its a hard fit but i am working on it so i will keep everyone posted PS. i bought this car about a year and a half ago and i knew two guys that are in Vettesofthesmokies.com Corvette club. they helped me get the top end off down to the malifoldbut all the timely patient stuff i am learning. just started this mechanic stuff. |
Posted on: 2011/11/30 3:51
Trae1976 | Re: C4, front mask is off, i need to get the checkerboard front piece off. | ||
Hi Chris, glad you made it here!
Posted on: 2011/11/30 13:20
Hey Trae, Glad to be here, im about ready to put it all back together. Getting excited
Posted on: 2011/11/30 14:54
