284 user(s) are online (224 user(s) are browsing Forums)
bobges Heating Problem
Bushkill PA
254 Posts
Took the car out Saturday for its last ride, 1991,auto Temp control, I hit the auto control and in a few seconds the fuse blew. I replaced the fuse checked codes ( no fault) when key is on engine not running i can turn it on raise an lower Temp and fan speeds all work,turn the car over and fuse blows, This is over my head any ideas will be appreciated. Thanks
Posted on: 2011/12/8 0:50
bogus Re: Heating Problem
I wonder if the resister is failing?
Posted on: 2011/12/8 1:08
woody1987 Re: Heating Problem
46 Posts
when you look under the dash the programmer for the ac is right above the gas peddle and the harness for the ignition switch chafes on the ac harness i would ck there to see if you have a bare wire. exactly which fuse?
JIM
Posted on: 2011/12/22 7:02
