216 user(s) are online (103 user(s) are browsing Forums)
woody3882 Shut off a warning light
Florida
51 Posts
I have the front right tire sensor light staying on, If I unplug the wire connector and or unplug and jump the terminals in the connector, would that shut the light off?. Or is it a resistance sensor? Is there any other ideas on how to shut off the dash low tire pressure warning light?
Thanks
Woody
Posted on: 2013/3/21 16:21
bogus Re: Shut off a warning light
Remove the bulb.
Posted on: 2013/3/21 18:42
woody3882 Re: Shut off a warning light
Florida
51 Posts
Do I have to remove the dash pad to get to the bulb cluster. Two days ago I removed the dash pad to replace the Passive Key transmitter, it was not as big a job as made out to be (three hours begining to clean-up), but I dont want to do it again just to pull one bulb. If I do have to pull the pad I might as well change all the bulbs with new ones. Are they all the same, and if so What are the bulbs replacement number.
Thanks
Woody
Posted on: 2013/3/21 19:36
oh, no... just the panel that covers the radio/AC/DIC area. Real easy.
Posted on: 2013/3/21 21:21
Florida
51 Posts
Would anyone known what size bulbs to use as replacements, and the best place to buy them would be. Are they still available new.
Thanks
Posted on: 2013/3/23 0:39
joeld Re: Shut off a warning light
I had this book marked from years ago, should help some.
http://content.mamotorworks.com/pdf/601004.pdf
Posted on: 2013/3/23 2:50
Florida
51 Posts
Great write-up
Thanks
Posted on: 2013/3/23 6:20
