290 user(s) are online (244 user(s) are browsing Forums)
GRIS, more...
knowledg3 instrument panel & manual transmission questions
1 Posts
Hi, I noticed my instrument panel and gages light either goes off or dims after a few minutes of operation and they frequently flicker off and on, especially when I run over a bump (but not always). This is on a 1984 cheverolet corvette coupe. was wondering if anyone had any suggestions or solutions to a fix?
recently I noticed a slow leak in my master clyinder, so I watched it for a few days, i noticed a burning smell (fluid leaking out of master clyinder and/or hose onto exhaust). Now all of sudden I can't go into reverse, i can put that shifter into the reverse position but when i release the clutch i hear a loud noise, all the other gears go into gear properly (and work) with minimal noise, but the reverse gear makes a really loud noise and the car will not move at all.
help please!!
Posted on: 2006/1/19 4:26
bogus RE:instrument panel & manual transmission questions
lemme address these one at a time.
1) The IP. You have to remove it and make sure all the bulbs are solid and connected well. It's rather easy... just a bunch of screws. The IP requires a bit of massaging to get out.
2) The tranny sounds sick... that is not a good sound at all. I would suspect the bad master cylinder has caused clutch or transmission damage. I would consider replaceing the master/slave and then flushing the fluid out of the transmission and OD unit.
beyond that... I donno what to say.
Posted on: 2006/1/19 5:56
