313 user(s) are online (276 user(s) are browsing Forums)
« 1 (2)
-=Jeff=- Re: Stereo change in 2014?
Bartlett, IL
573 Posts
HD Tuner is installed. Works well, finishing the bezel then I can paint it. Waiting on the USB Tuner I want to add a well then I should be set. I will add a regular USB cable for use with the EEPROM burner. Having ALDLDroid on the tablet will be a nice feature. The set up is coming together
Posted on: 2014/3/27 3:41
-=Jeff=-
1990 Corvette ZR-1 #1051
bogus Re: Stereo change in 2014?
cool!!!
Posted on: 2014/3/27 15:27
Bartlett, IL
573 Posts
getting closer
Posted on: 2014/4/4 14:46
-=Jeff=-
that looks GREAT!
Posted on: 2014/4/4 16:52
Bartlett, IL
573 Posts
Well,
The tablet is working good.. I have a few things to contend with, one being issues with reception which I have narrowed down to the actual antenna but when the signal is solid it sounds great.
I am also working on new bezels, this time I am being bold, I am making the 90-91 bezels fit wider for the 94 driver side panel I have. I just think the 94 console side is much cleaner than the 90 side. The bezels are coming along I need to decide where to put the power key and volume and balance knobs on the radio one, the opening has been cut larger too. I had to do this to access the touch button on the bottom.
here is the modded console bezel.. we the beginning of it.. I am waiting on the ABS/Acetone to harden, then I can remove the clamps and add more to finish the end
I used an ABS/Acetone mixture to glue the pieces together and it makes a nice solid bond. I will need a spot filler or something to glaze over these and sand them smooth.. looking forward to getting these new panels done
Posted on: 2014/4/19 3:09
-=Jeff=-
Bartlett, IL
573 Posts
Oh yeah, the change slots will be used for some control switches
One of the issues I had was alternator whine. Turns out I need a ground reference at the front by the tablet. I also need more dynamic headroom for sound, I instaleld my Phoenix gold PLD-1 line driver and it cured both problems
I will probably add an EQ ( mainly for the HD tuner) but for now everything seems to be working fine
Posted on: 2014/4/19 3:10
-=Jeff=-
cool!!!
Posted on: 2014/4/21 15:16
« 1 (2)
