193 user(s) are online (159 user(s) are browsing Forums)
byedan no wipers
7 Posts
ok guys here is the deal i had a new transmission installed in my 94 vette. i picked the car up from the garage today and found out my wipers are not working. They where working when i dropped the car off. i checked the fuse and it is good. the washer nor the wipers are working it is like the main power or ground to the circut is dead but i do not have a fsm and do not know where to start testing it. Thanks for the help Daniel
Posted on: 2008/5/8 18:26
josephf31 Re: no wipers
New Jersey
375 Posts
Going strictly from memory, sounds like it could be the switch, check the turn signal stalk to make sure it's all the way into the steering column, also right behind it (to the front of the vehicle) possibly under a small plastic cap is an electrical connector which I think is for either the wipers and/or cruise control...
Posted on: 2008/5/8 18:50
byedan Re: no wipers
7 Posts
thanks i will check there also. Do i have to take the steering colum apart to get to the plug. which one is the power plug to the wiper motor. i think all of the wiper motor function with the was function go through the controller on the motor is this wrong
Posted on: 2008/5/8 19:59
7 Posts
myself and a freind went out to the car and he tapped on the wiper cover and they started working and then he wiggled the wires going into the front of this and it stopped wokring. so do i need a new cover or can this one be taken off and cleaned? als witch wire going in is the hot wire and witch is the ground thanks
Posted on: 2008/5/8 21:00
Randy93 Re: no wipers
Winter Park, Fl
51 Posts
There is a ground that is connected to the tranny where it mates to the engine on the drivers side. When I had my tranny rebuilt, they forgot to put it back on. Caused me all kinds of problems.
Posted on: 2008/5/10 16:43
