170 user(s) are online (119 user(s) are browsing Forums)
ianh constant fan
uk
3 Posts
hi all.New to the site.Have an 88' coupe, in the UK. Lovely though she is, the electric fan stays on constantly. She sits at around 180 degrees. I've been told that some a/m chips cause this. You guys would know, so I'm asking!!
My main concern is that the fan motor will burn out....
Posted on: 2007/1/26 12:11
Ian Harris
88´ Corvette
03´ ZRX 1200
Alcee1 RE:constant fan
Los Angeles
277 Posts
Do the fan come on when you first start the car, or does it come on when the temp hits a certain degree?
Posted on: 2007/1/26 15:45
ianh RE:constant fan
uk
3 Posts
hiya. it comes on and off with the engine.
Posted on: 2007/1/27 17:26
Ian Harris
88´ Corvette
03´ ZRX 1200
Los Angeles
277 Posts
If your saying what I think your saying, then it sounds like your fan is hard wired and not wired to the temp switch
Posted on: 2007/1/28 3:01
