311 user(s) are online (248 user(s) are browsing Forums)
Jim L98 Rebuild Help
2 Posts
Last year I began an upgrade to my 88 GTA and then was hospitalized for a number of months. I'm trying to reassemble the motor and having some problems. Hopefully I can get some tech help here.
I replaced the stock cam with a ZZ4, replaced the stock rockers with 1.6 ratio rollers, replaced the stock injectors with 23 lb/hr bosch, added some Hooker headers, blocked the EGR and removed the AIR pump. At this point I've replaced the heads and the intake manifold/runners (not the plenum) and the front end (except the alternator and serpentine). Now I have to figure out which (if any) sensors and solenoids are no longer needed, which wires to cut, how to replace & reconfigure my vacuum hoses (other hoses?) and what to do with my PROM (I've been using a hypertech with a 160deg theromostat).
Ideas, suggestions, advice, comments ?????
:thumbright:
Posted on: 2007/2/25 17:25
bogus RE:L98 Rebuild Help
Sorry to hear about your illness, glad to hear you are back in action!
Even tho it's not a Vette, a few thoughts on your project:
1) The EGR is NOT your enemy. I find that most folks who remove it don't know what it does. It does one thing, and does it well, that effect two results. It feeds a small amount of exhaust gas into the intake. The results are two fold, one, the reduction of NOx emissions and the other, a reduction in combustion temperatures, which results in less chance of detonation. For specifics, you really need to get the Helm Factory Service Manual for the year of your TA. It will have the harness diagrams you need, both wiring and vacuum.
2) As long as you are using EFI, 95% of the sensors will stay. About the only two things that can go are the pre-cats (done, thanks to the headers, thats even if the Fbody had them) and the vapour recovery. EFI sensors have been confused with being an emissions control device, but the reality is that EFI is an EFFICIENCY DEVICE. It needs the O2, knock, MAF (or MAP, or both, depending on vintage) and temp sensors so it can calculate the most efficient charge it can deliver. Otherwise, you have a carburetter.
3) A couple of thoughts regarding the exhaust system. I am a fan of high flow cats. They do a couple of things, one being is apply a touch of back pressure that helps savaging, takes some of the boom off the headers, removes that uncontrolled combustion smell (fine at the track, annoying on the street) and as a result, keeps the air clean. Win-win-win in my book. The rest of the Fbody's exhaust is a mess... the chassis sucks for fitment, check with SLP for some options.
4) The ECU is not going to be easy. You will need a dyno to do it right, but really, I don't think you have done enough to require it. It's not like you raised compression or made a 383 out of it. The changes have been minor. I would recommend an Adjustable Fuel Pressure Regulator, it will help you tune the fuel flow to the injectors better. You may want to investigate some of the laptop based systems that work through the printer port. They are pretty cool, but I can't remember brand names off hand. The mid-80s ECUs are rather crude and are not heavily supported anymore.
A couple of websites for you:
1) www.corvetteplenum.com - he machines the stock TPI plenum to improve breathing.
2) www.thirdgen.org - specializes in your vintage F-bodies.
Posted on: 2007/2/25 20:25
Jim RE:L98 Rebuild Help
2 Posts
[quote="bogus"]Sorry to hear about your illness, glad to hear you are back in action!
Thanks for the help!!! I wasn't even aware of the Helms Service Manual ... was trying to use Clymer and Haynes and Chilton (I think all three are pretty crappy when it comes to details and specifics). I found a Service Manual on ebay and have it coming. I'm sure glad I came to this forum with my problem! :thumbleft: :thumbright:
Posted on: 2007/2/27 5:24
cool!
If you need us, you know where we are.
Posted on: 2007/2/27 6:32
