Black84 | Switching CFI to TPI | ||
Hi all,
I purchased a 1984 CFI car and have driven it for a while. I am doing a changeover to put a TPI from a 1985 Corvette in the car. Has anyone done this type of changeover and does anyone have any input? thanks, Brian |
Posted on: 2006/5/10 17:00
bogus | RE:Switching CFI to TPI | ||
well... other than it's more work than it's worth.
I would consider saving the time and effort and upgrade to something with power potential. hell, you can do a lot to the Xfire that will get it up to over 300hp... with no effort. |
Posted on: 2006/5/21 2:18
Alcee1 | RE:Switching CFI to TPI | ||
I chose a different route, I thought about doing the changeover also but I quickly changed my mind when I realized how much work was needed just for an extra 20HP, then once you get the TPI on you will still have to do/buy more to get the horsepower out the motor. You could just get a crate motor or build up what you have already depending on how much HP you want. I went with the build up method ie heads, cam, bored TB's, roller rocker's, 3.54 rear gears, Built tranny with 2800 stall TC, MSD, and so on. I have just over 300HP (300.9) to be exact to the crank, but that's alot better than the stock 205HP. I wish you luck in whatever you decide to do.
Alcee |
Posted on: 2006/6/5 19:30
Edlebrock Heads, 2030 cam, X-ram w/EGR, 1.6 R/R, Bored TB´s, AFPR, Pro-built Tranny, Vigilantly 2600, Transgo, Dana 44 3.54, Hardened Pushrods & Head Bolts, Custom performance chip, K&N, Double roller timing chain, Aluminum radiator & flex hose, MS |
Alcee1 is the resident poster child for what CAN be done with the Crossfire.
BTW, his C4 is BAD to the bone!!!! The bronze/gold exterior matches nicely with the tan interior... he also has a wood dash kit - the ONLY one that I have ever seen that looks right. Just a lovely ride, all the way around. Sounds awesome, too. :thumbright: |
Posted on: 2006/6/5 20:04
xrcrx | CFI | ||
I'm also sticking with the crossfire. I'm currently having an intake ported and modified. I'll be adding 1.6-1 rockers. The cold air mod is done w/K&N filter. gears are also in the works. Switching to TPI would require changing the harness also. Just too much work for not enough gain IMHO.
Eric 84 Z51 |
Posted on: 2006/7/3 14:53
