162 user(s) are online (135 user(s) are browsing Forums)
1st Gear: 1.76/1.82
2nd Gear: 1.00
- 14 Bolt Pan.
- Vac...
CSS996 Southern CO Hurst install experience?
Mega Guru
Central PA
3644 Posts
OK, so I finally have a Hurst shifter (with bearings) ready for install. Not something I feel I can tackle. Anyone semi local have any experience with this install? I'd rather pay a friend than a Corvette shop. They quoted me about $350 for the install.
I'm pretty excited to get this thing in the car, so I probably can't hold out too long. I'll take it up the bum on this install if I have to, but I'd rather not.
If anyone can help, I will supply beer, pizza, a 1:8 scale 1985 Corvette model, or whatever. Some cash too.
Lemme know!
Posted on: 2007/8/31 20:58
Currently "Between Vettes".
bogus RE:Southern CO Hurst install experience?
drop the exhaust.
remove the knob
remove the console
remove the rubber boot.
remove the old shifter
reverse process.
It ain't all that hard. I saved mine for a clutch change.
Posted on: 2007/9/1 0:02
CSS996 RE:Southern CO Hurst install experience?
Mega Guru
Central PA
3644 Posts
I'm thinking I need to lift the front end up a little for that. I don't have a safe way to do it. I'll ask around and see if any of my buddies have access to some ramps or something. I suppose buying ramps is cheaper than the install!
Posted on: 2007/9/1 2:46
ramps won't do it... you really need to get all 4 corners off the ground.
may I suggest:
http://www.drivewerks.com/catalog/sho ... L/POR_TOOL_ACHyd1_pg1.htm
That is by far the BEST floor jack, on earth, period. No questions asked. I have one and LOVE IT.
It ain't cheap... but it rocks... and lifts 29".
And a pair of these:
http://www.drivewerks.com/catalog/sho ... L/POR_TOOL_ACHyd1_pg5.htm
Well, all 4 actually.
It is the best $900.00 you will EVER spend. It's a one time investment in your health and wellbeing.
Posted on: 2007/9/1 3:28
Mega Guru
Central PA
3644 Posts
:sad5: NINE HUNDRED DOLLARS!!!
I think I'll pay for the install.
Posted on: 2007/9/1 3:36
yes, $900... but think of all the $350+ bills you would be able to absorb because of those pieces...
exhaust upgrades... clutches... oil pan... all the fluid changes...
Posted on: 2007/9/1 18:38
