493 user(s) are online (321 user(s) are browsing Forums)
Lamison Rear Suspension
2 Posts
Hello new to the site new to corvette's i was wondering if some one could answer a question for me?
Here it goes
I was getting my 1984 corvette aligned today the tech told me I was missing parts on the rear transversed leaf where the bolt goes through and the cushions are. On the car there is top of bolt, cushion, spindle nothing then spring, bushing, nut, cotter pin. he said I was missing 2 bushings and a sleeve on the inside between spindle and spring. Is this true? Because I can not fing replacements for this. Please help
Thank you
Posted on: 2006/6/23 2:09
Alcee1 RE:Rear Suspension
Los Angeles
277 Posts
If you describing what I think you are then you are not missing anything, mine is the same way.
Posted on: 2006/6/23 17:46
Lamison RE:Rear Suspension
2 Posts
Thank you for your reply
I will try and get a photo so we can make sure we are on the same page
Thank you again
Posted on: 2006/6/24 2:15
bogus RE:Rear Suspension
IIRC, on my 92, one of those spring bushings has an extension that acts kinda like a sleave...
Posted on: 2006/7/1 20:25
