rsawyer84 | pcm/ecm for 84 | ||
everything i read tells me that nothing can be done with the 84 ecm only 85 and up? is that true? can it be modified, can i buy cable to hook to laptop and use software for tunning on the 84?
Please help... |
Posted on: 2008/10/23 2:06
84 Proud Owner |
Alcee1 | Re: pcm/ecm for 84 | ||
You can start by checking out this thread......
http://www.crossfire.homeip.net/index.php?showtopic=543 |
Posted on: 2008/10/23 2:39
Edlebrock Heads, 2030 cam, X-ram w/EGR, 1.6 R/R, Bored TB´s, AFPR, Pro-built Tranny, Vigilantly 2600, Transgo, Dana 44 3.54, Hardened Pushrods & Head Bolts, Custom performance chip, K&N, Double roller timing chain, Aluminum radiator & flex hose, MS |
