306 user(s) are online (244 user(s) are browsing Forums)
BlackDragon Additional fuse panel ??
Toronto, Ontario
6 Posts
I changed the worn belt mouldings on my 92 coupe this week, (not a job id like to do again), and while removing the power door lock harness, I generated a spark (some sort of short), now my power lock does not work if I push the door lock from inside the car, but it works with my viper remote control. I have gone through every fuse on the passenger side dash panel, and every one is fine. I am convinced that I shorted a fuse, and am wondering if there is any other fuse panel in this car.
Confused ??
Posted on: 2006/4/30 8:14
bogus RE:Additional fuse panel ??
yes, there is one... annoying, when you think about it!
It's under the right knee bolster. It requires you to remove the black plastic panel below the carpeted panel.
Oh, this really needs to be in tech, moving accordingly!!! Sorry for the delay!!
Posted on: 2006/7/11 21:55
freakd RE:Additional fuse panel ??
727 Posts
cool, thanks for the info :thumbright:
Posted on: 2006/7/11 22:04
