192 user(s) are online (122 user(s) are browsing Forums)
The Natio...
kelley antenna relay
thomasville ga
122 Posts
found 2orange wires corroded off the antenna relay on the 94 vert.i assume they both go to the same terminal,,,but the conector is corroded ,can just one be replaced or do i need to get a new base unit? thanks,,,
Posted on: 2009/6/7 13:26
bogus Re: antenna relay
if they are that corroded, I would get new parts.
I am just not sure what a "base unit" is. Are you referring to the harness connector? If so, get a new one.
Also, inspect the rest of the wiring in that area for additional corrosion issues. If it has happened once, it more than likely will happen again.
Posted on: 2009/6/7 17:07
kelley Re: antenna relay
thomasville ga
122 Posts
yes the conector, who would have one? and the wires are live what do they run? my 94 manual says look in the 93 book for all audio info,,,,duh,, guess i missed that part when i got my books,oh well thanks for the help...
Posted on: 2009/6/8 22:02
