285 user(s) are online (241 user(s) are browsing Forums)
redvette93 tire sizes
Michigan
1 Posts
I want to put 18x9.5 wheel on all 4 corners, I would like to know the biggest tires sizes I can fit on them without any problems.
Thanks
Posted on: 2005/11/14 16:37
bogus RE:tire sizes
if I remember my tire math correctly, the key is section width.
I am pretty sure the max is a 295... but a 275 is better.
I would run the tire size though the tire racks website and see what it says.
Posted on: 2005/11/14 19:26
cosmicvette RE:tire sizes
2 Posts
heres a useful tool when selecting/deciding tire sizes:
check out this link for a tire size calculator > [url]http://www.miata.net/garage/tirecalc.html[/url]
Posted on: 2006/2/4 10:14
vetasaurus RE:tire sizes
2 Posts
ive got 315/40/ 17 on rear fit no problems 18 are just going to be higher slightly depends how low it is.
Posted on: 2006/2/21 6:52
VR-92 RE:tire sizes
68 Posts
With a standard 9.5 in wheel a 315 is too wide. It will fit but its not very smart. You need an 11 in rim to fit the 315s.
On a standard 9.5 I wouldn't go bigger than 285s.
Posted on: 2006/2/21 20:11
