Lamison | Rear Suspension | ||
Hello new to the site new to corvette's i was wondering if some one could answer a question for me?
Here it goes I was getting my 1984 corvette aligned today the tech told me I was missing parts on the rear transversed leaf where the bolt goes through and the cushions are. On the car there is top of bolt, cushion, spindle nothing then spring, bushing, nut, cotter pin. he said I was missing 2 bushings and a sleeve on the inside between spindle and spring. Is this true? Because I can not fing replacements for this. Please help Thank you |
Posted on: 2006/6/23 2:09
Alcee1 | RE:Rear Suspension | ||
If you describing what I think you are then you are not missing anything, mine is the same way.
Posted on: 2006/6/23 17:46
Edlebrock Heads, 2030 cam, X-ram w/EGR, 1.6 R/R, Bored TB´s, AFPR, Pro-built Tranny, Vigilantly 2600, Transgo, Dana 44 3.54, Hardened Pushrods & Head Bolts, Custom performance chip, K&N, Double roller timing chain, Aluminum radiator & flex hose, MS |
Lamison | RE:Rear Suspension | ||
Thank you for your reply
I will try and get a photo so we can make sure we are on the same page Thank you again |
Posted on: 2006/6/24 2:15
bogus | RE:Rear Suspension | ||
IIRC, on my 92, one of those spring bushings has an extension that acts kinda like a sleave...
Posted on: 2006/7/1 20:25
