bigmoe | Different Corsa systems for the LT1? | ||
I was looking at Corsa's web site and under "sounds" they have Touring, Sport and Xtreme. I found pt # 14116 that is the "sport" and I found pt # 14118 that doesn't say what it is. I probably want the Touring system for my LT1. Anyone know the part number?
Posted on: 2010/5/25 23:22
bogus | Re: Different Corsa systems for the LT1? | ||
The different versions are for the C5.
All we get is the standard version... sorry... the different part numbers indicate OBDI or OBDII installations - meaning - does it have a down stream O2 sensor? If you have a 1996, then the answer is yes. |
Posted on: 2010/5/26 1:18
bigmoe | Re: Different Corsa systems for the LT1? | ||
Okay that clears it up. Mine is a 94.
Posted on: 2010/5/26 11:21
and you get the OBDI system.
Posted on: 2010/5/26 14:18
