208 user(s) are online (178 user(s) are browsing Forums)
1st Gear: 2.43
2nd Gear: 1.49
4th Gear: 0.75
Reverse: 2.07
iCorvette why do poly bushings feel soft on the upper control arms?
302 Posts
just got a set for the fronts and the uppers seem very rubbery, compared to regular polys, is there any advantage in going through the trouble to put them in?
Posted on: 2010/12/30 20:16
bogus Re: why do poly bushings feel soft on the upper control arms?
what are you comparing? Same brand, same kit, one for front one for rear? or what?
I would think that compared to the crap rubber that is in there, the poly's would be an improvement.
Posted on: 2010/12/30 20:27
iCorvette Re: why do poly bushings feel soft on the upper control arms?
302 Posts
i squeeze it and the single upper poly seems firm like poly should be and the 2 part uppers seems like just rubber, they have energy suspension number codes on them I bought them from a CF member, who bought a master set and went with global west stuff for the fronts, he had these laying around.... I saved a few bucks
Posted on: 2010/12/30 20:46
