298 user(s) are online (248 user(s) are browsing Forums)
teebee, more...
Steve40th DAMN IT, Left headlight wont go up all the way...
1114 Posts
I replaced the gears years ago with bronze and the delrin bushings. I cant believe I need to do it again.
When I turn the lights on, the drivers side only goes half way and the knob on top is spinning pretty darn fast. Once it stops, I turn it to get the light all the way up.
Posted on: 2011/6/3 20:49
Ko'u ohana aia ku'a ikaika
Matatk Re: DAMN IT, Left headlight wont go up all the way...
Bushings are shot. I've read not to use the bronze gear, though, due to extra weight and it chews things up faster. I'm not sure if that's an internet rumor or not.
Sucks about having to do the job again
Posted on: 2011/6/3 23:04
Steve40th Re: DAMN IT, Left headlight wont go up all the way...
1114 Posts
its not really a tough job. just a pain
Posted on: 2011/6/4 0:11
1114 Posts
I am wondering if I can just pull the roll pin, then the cover where the gears are. Seems like we take allot off to get to the gears when they are under the cover/gear, which has three bolts and the roll pin keeping the shaft in.
http://home.comcast.net/~zrjuan/headlight.html
Posted on: 2011/6/4 2:10
1114 Posts
Well, here is my bushing. They all are the right size and in great shape. The bronze gear had a few pieces(very) of old bushing or dirt on the gears, but was clean otherwise.
[IMG]http://i280.photobucket.com/albums/kk189/rivary0006/bushing2.jpg[/IMG]
Thats a 7/16 wrench to show it meets the correct size of less than .465.
Posted on: 2011/6/4 3:54
Strange. I wonder if the debris was making the motor think it hit the limiter.
Did you end up removing the whole assembly? I don't see you being able to get the cover off without removing it?
Posted on: 2011/6/4 11:41
1114 Posts
I took everything apart. Nothing damaged, or stripped. I then turned the motor by hand using the knob. Everything turned fine. The only thing that can strip is the metal rod that goes through the brass gear, as it has teeth on it to. But its fine and so is the brass gear, and it went on tight. I put a little loctite for shits and giggles on the rod.
Posted on: 2011/6/4 11:51
The only other thing I could think it would be is the external linkage. I accidentally bent one of the washers and it provided enough resistance the headlight wouldn't go up.
Posted on: 2011/6/5 12:35
