277 user(s) are online (214 user(s) are browsing Forums)
C4Williams C4 Leaf collector near Windshield. Both sides. Do not know Name of Part
Kingsport, TN
176 Posts
There is a container that is on both sides of my 1985 that collects leafs and such that was under/near the windshield i do not know the name of part so i can buy new ones.
Please do your best to answere
Thanks in advance!
Posted on: 2011/11/22 4:51
bogus Re: C4 Leaf collector near Windshield. Both sides. Do not know Name of Part
Are these the screens? or the little rubber things under the hood latch that look vaguely like condoms?
The rubber things are designed to drain stuff out of the void under the windshield cowl.
It really isn't a bad idea to clean the area out very so often. It's not so much like the area can rust, but why let moldy stuff form in there? You can use a hose at lowish pressure carefully flood them, lifting out the heavy stuff and then letting the small stuff fall through.
The best fix is a filter that you can either make or buy from Ecklers. It's basically home AC filter material, and it will do wonders to keep that area clean.
I don't see anyone selling the drains... but I am sure you can find them on the used market. Contact Jason at www.vette2vette.com
Posted on: 2011/11/22 6:22
C4Williams Re: C4 Leaf collector near Windshield. Both sides. Do not know Name of Part
Kingsport, TN
176 Posts
Thanks a bunch you are correct, i am in the process of doing a home restoration. It is coming along great i hope to post some pics
thanks again for your help
Posted on: 2011/11/23 1:05
cool! can't wait to see the pics! Are you doing stock or going custom?
So I was right... was it the screens or the rubber things?
Posted on: 2011/11/23 1:12
Matatk Re: C4 Leaf collector near Windshield. Both sides. Do not know Name of Part
Welcome to the site.
From your description, what you are referring to is called a cowl drain screen. I don't know of any aftermarket sources offhand, but you can find them on ebay, and from the used parts vendors.
http://www.ebay.com/itm/1984-96-Corve ... Parts_Accessories&vxp=mtr
Posted on: 2011/11/23 2:18
Kingsport, TN
176 Posts
Thanks for the post Webmaster, i was needing that as well and had searched previously with no luck Thanks Very Much.
Love the Website.
Posted on: 2011/11/23 4:19
Ok, if you were looking for the cowl drain tube, check here - it's the first place that came up on google, so other vendors might have it cheaper:
http://www.corvettepartscatalog.com/i ... h=174_198&products_id=601
Good luck,
Posted on: 2011/11/23 12:23
Kingsport, TN
176 Posts
It was the Rubber Holder<
i am doing a stock restore with some performance add ons.
Everybody have a great Thanksgiving
Awesome links as well
Posted on: 2011/11/23 21:05
CorvetteArchives Re: C4 Leaf collector near Windshield. Both sides. Do not know Name of Part
65 Posts
I don't recommend adding those foam "air filters" over the screens. I bought a set and they retained water and gave the car a musty smell. :-(
Posted on: 2011/11/27 3:55
