bobges | Heating Problem | ||
Took the car out Saturday for its last ride, 1991,auto Temp control, I hit the auto control and in a few seconds the fuse blew. I replaced the fuse checked codes ( no fault) when key is on engine not running i can turn it on raise an lower Temp and fan speeds all work,turn the car over and fuse blows, This is over my head any ideas will be appreciated. Thanks
Posted on: 2011/12/8 0:50
bogus | Re: Heating Problem | ||
I wonder if the resister is failing?
Posted on: 2011/12/8 1:08
woody1987 | Re: Heating Problem | ||
when you look under the dash the programmer for the ac is right above the gas peddle and the harness for the ignition switch chafes on the ac harness i would ck there to see if you have a bare wire. exactly which fuse?
JIM |
Posted on: 2011/12/22 7:02
