176 user(s) are online (99 user(s) are browsing Forums)
Early SBC
4.3L 265ci - 1955 thru 1956
4.6L 283ci - 1957 thru 1962
4.9L 302ci - ...
pappyfreebird floppy windows
1028 Posts
what keeps the door windows from floppin when open door ? drivers side is floppy (glass leans in when open door)
Posted on: 2008/1/12 1:45
94z07 RE:floppy windows
94 Posts
There are a series of pads across the top of the inside of the door. These pads can be adjusted in and out to come to the proper grip on the window. Too much and the window won't move. Too little and the window will flop. The bolts that hold these pads in place are the very ones used by many to cure the sagging door panel syndrome.
Posted on: 2008/1/16 15:40
pappyfreebird RE:floppy windows
1028 Posts
thank you...ill have a look next time its uncoverd...more snow on way so shes sitting thanks again
Posted on: 2008/1/16 16:19
