istter1 | 87 vet clutch pedal switch | ||
87 Corvette clutch pedal Switch
Found my starting problems . Losing 4 volts at startup from switch. 8 volts only coming through most of the time. Not enough to turn over starter. Had a feeling it had nothing to do with the vehicle antitheft control. Does anyone have a part number the correct name or where to find one. I assume it is dealer only and not made any more. Steve |
Posted on: 2015/1/16 1:20
Matatk | Re: 87 vet clutch pedal switch | ||
I've always seen it as a clutch safety switch.
I believe it's discontinued. Maybe a similar one can be modified? |
Posted on: 2015/1/16 2:26
istter1 | Re: 87 vet clutch pedal switch | ||
found a new one on ebay
Thanks paid $100 it will be here sat. found a re built one later for $60. That's life we always take a chance on ebay. I bought this part from Carter in Livermore Part is in USPS already http://stores.ebay.com/corvettepartsa ... er?_trksid=p2047675.l2568 Your right safety switch |
Posted on: 2015/1/16 4:13
Edited by istter1 on 2015/1/16 4:59:31 |
hcbph | Re: 87 vet clutch pedal switch | ||
I know this has been out there for a while, but the clutch switch on manual transmission cars can be bypassed with the understanding it's now possible to start the car with it in gear and the clutch not depressed.
Unplug the wire off the switch and make a jumper wire for it and you're done. |
Posted on: 2015/3/11 1:00
