joesnipe7 | another newbe with questions | ||
hi everybody,newbe here who just got my new midlife crisis toy,an 87,oh i love this thing.been driving toyotas for years,this beast brings back memories of hot rodding days(before wives and kids).i have a few questions,1 some of the number lights on my dash don't work right,8 looks like o etc,what is involved with repairing?2,low coolant light keeps coming on,even thou level is full,sensor is new,3 when cruising has a loud howl like from rear end when lightly accelerating,let off throttle just a little,howl goes away,any ideas?thanks and this forum rocks,i've already learned so much just reading.
Posted on: 2008/2/17 15:09
Midnight85 | RE:another newbe with questions | ||
The electrical problems could be
caused by a bad ground. These cars are notorious for ground problems. Check & clean the grounds you may have to pull the cluster and clean the connection. If this doesn't work it may need re- conditioning. The low coolant light I have no idea, my '85 doesn't have one. The howl from the rear end COULD mean it is in bad shape but check the fluid level first. If the car was raced or just abused then it may be time for a new ring & pinion. |
Posted on: 2008/2/17 15:20
HORSEPOWER! Some is good, more is better, too much is just right. |
joeld | RE:another newbe with questions | ||
I'll give you the standard answer for the low coolant problem: Burp the coolant system. This is usually the problem.
Joel |
Posted on: 2008/2/17 19:45
1989 Coupe,L98 automatic |
dan0617 | RE:another newbe with questions | ||
The noise from the rear could be a bearing, or could be a performance rear gear installed and not perfectly set up. I agree with the above on burping the coolant system. I start mine with the cap off and let it run, even if it spews out some antifreeze, till the thermostat opens. When it opens the level in the radiator drops out of site. Instantly when that happens you need to be adding antifreeze till it is full. Then wait till the thermo opens again and fill it again. After the second time put the cap on and you are done. Just watch the temp a little because if your thermostat would happen to stick while you are standing at the radiator waiting for it to open you will overheat the car. There are other ways of doing this but this is the method that works for me.
Posted on: 2008/2/17 20:15
bogus | RE:another newbe with questions | ||
Welcome aboard!
My wife has an 87, so I have a little experience with them. The low coolant sensor is a joke, to be honest. It's poorly placed on the radiator... as such, it kicks as many false warnings as real ones. The digidash is a different animal... they can be serviced, tho. The rear axle? I would check the tires. When I got my 92, the rear end howl was caused 100% by bad tires. |
Posted on: 2008/2/17 20:45
