freakd | ok, antenna motor replacement help needed | ||
seriously, on my 87, the 2 bezel nuts are welded together, it seems, i just can't get them apart!!! any easy way to do this, without hurting the car??? i'm taking the new motor to carlisle on the off chance i could get some help. let me tell you, this is driving mne nuts.
so when i turn the nuts, the whole motor turs, which means the antenna mmast is tight in the bezel nuts. if i unbolt the motor from the frame, and pull down on it, bringing the mast down. will this release enough pressure on the nuts to let them seperate??? any help is much appreciated :thumbright: |
Posted on: 2006/8/15 15:50
bogus | RE:ok, antenna motor replacement help needed | ||
you mean the nut that holds the antenna to the body?
wow... have you hit the area with some PB Blaster? |
Posted on: 2006/8/15 18:05
freakd | RE:ok, antenna motor replacement help needed | ||
you mean the nut that holds the antenna to the body? |
Posted on: 2006/8/15 21:37
even if i do that, i'm not sure how to get a wrench on the nut
Posted on: 2006/8/15 21:45
there is a special socket for that nut.
need one? |
Posted on: 2006/8/16 4:22
you got one??? i could use it, you still have my info??
Posted on: 2006/8/16 12:57
sure... I will send it....
go ahead and resend me your address info... |
Posted on: 2006/8/17 5:15
