rsawyer84 | Door Handle/ Lock Help | ||
in my efforts to finish the 84 that i am putting back together, i need to replace the driverside out door handle. i have the used one i bought from ebay and now i want to take the lock cylinder and move it to this one, i puled and twisted a few times and nothing seemed to move, anyone know how to take the lock assembley off?
Posted on: 2008/9/14 1:02
bogus | Re: Door Handle/ Lock Help | ||
you mean separate it from the handle assembly?
gee... I have no clue... the Helm for 84 has no docs, so I will have to check my 92. It's in the other room, if you can hang until the USC game is over... |
Posted on: 2008/9/14 2:51
rsawyer84 | Re: Door Handle/ Lock Help | ||
yeah...and good luck with USC!! Michigan rules
Posted on: 2008/9/14 2:54
CentralCoaster | Re: Door Handle/ Lock Help | ||
You have to remove the door panel. It's been awhile, but its simply held in with screws from the inside of the door. I think I had to remove quite a bit from the door, including the aluminum inner panel. Also there's a plastic switch that goes on it as well, that is needed if you have an alarm.
Posted on: 2008/9/14 7:35
