300 user(s) are online (257 user(s) are browsing Forums)
Print in friendly format Send this term to a friend  Ruby
Refers to 1993 Anniversary Editions.
These are the actual cars honored as anniversary cars. They have RPO Z25 to prove it....
TommyT-Bone Service ABS/ABS Active/Vats
So I've been a bad, bad boy and let my Corvettes sit for a few of weeks because the weather sucked. To start off with the battery in the 91 was weak and wouldn't turn over. Put a charge on it for a couple of hours and I went to start it and the security light stayed on, wouldn't start. Screwed around with cleaning the key, opening the locks , disconnecting the battery, combinations of stuff till I finally got the light to go out. What's the best way to reset vats anyway?
Next, I get it started and the SERVICE ABS light is on. I let it warm up and the light goes out. Get in the car and the ABS ACTIVE light flashes on for a few seconds and goes out Is it something to concern myself with or is it the gremlins of October.
Posted on: 2008/10/5 18:19
bogus Re: Service ABS/ABS Active/Vats
it's because it sat.
Clean the battery posts (you don't mention doing that). I also prefer to charge the battery with it disconnected from the car. It can put voltage back into the alternator and hurt the voltage regulator and/or diodes.
Check to be sure the brake fluid is up to level. I would consider a flush, too.
Posted on: 2008/10/5 18:59
