159 user(s) are online (126 user(s) are browsing Forums)
rsawyer84 silence the road noise
Trenton MI
38 Posts
as i continue to bring my 84 back to life, i had the tires balanced high speed today and have put the doors for the most part back together. can anyone give me some suggestions for silencing road noise like cane i put anything in doors etc.
Posted on: 2008/10/23 1:53
84 Proud Owner
bogus Re: silence the road noise
the later C4s used an interior door panel cover. You can find this either at www.vette2vette.com or any of the parts vendors.
Also, I have found that frost king helps a lot.
how old are the tires? as they age, they harden...
Posted on: 2008/10/23 3:15
CentralCoaster Re: silence the road noise
That door panel cover looks like a great idea, so much noise comes through the door and from rattles in the door. Mine just came with a thin sheet of plastic in there. Did GM remove that when the foam piece was added?
One thing that won't really help you, is dynamat type stuff. It's intended to dampen out low frequencies in thin panels that would otherwise vibrate. It doesn't absorb white noise well.
Posted on: 2008/10/23 3:28
rsawyer84 Re: silence the road noise
Trenton MI
38 Posts
Tires are good, just the typical road noise, i will follow site... thanks
Posted on: 2008/10/23 14:18
Trenton MI
38 Posts
there was no foam i nthe door when i took it apart.
Posted on: 2008/10/23 14:21
84 Proud Owner
there wouldn't be. They started the foam in 1990.
Posted on: 2008/10/23 14:49
