345 user(s) are online (308 user(s) are browsing Forums)
'W' Series:
5.7L 348ci - 1958 thru 1964
6.7L 409ci - 1961 thru 1965
7.0L 427ci (Z11...
rsawyer84 pcm/ecm for 84
Trenton MI
38 Posts
everything i read tells me that nothing can be done with the 84 ecm only 85 and up? is that true? can it be modified, can i buy cable to hook to laptop and use software for tunning on the 84?
Please help...
Posted on: 2008/10/23 2:06
84 Proud Owner
Alcee1 Re: pcm/ecm for 84
Los Angeles
277 Posts
You can start by checking out this thread......
http://www.crossfire.homeip.net/index.php?showtopic=543
Posted on: 2008/10/23 2:39
