Anonymous | '96 rear brakes | ||
I was gonna put new rear break pads on my '96 myself but a friend told me without the right equipment I could ruin my ABS. Should I get it done at a shop or is it not too hard to DIY? Thanks.
Posted on: 2006/1/11 19:58
VR-92 | RE:'96 rear brakes | ||
Its not hard. Do it yourself. You certainly aren't going to screw up the ABS.
Just bleed the brakes correctly after you install the new pads. I use the old fashioned find a friend to pump the brakes and add fluid when needed. Wait for the outside line to quit letting out any air bubbles and your done. |
Posted on: 2006/1/12 21:43
Anonymous | RE:'96 rear brakes | ||
Alright, sounds good. Thanks. Are the pads all I need or do I need some other parts?
Posted on: 2006/1/13 20:43
bogus | RE:'96 rear brakes | ||
you might want to consider rotors, but rears don't take the beating fronts do, so I would not fret that. Cutting is doable at least once.
There is a lot of misinformation about ABS and doing maintenance on it... there is nothing to worry about! Deal with it like you would a conventional braking system and all will be fine. I suggest bleeding it and replacing the fluid with Valvoline Synpower Brake Fluid. Great stuff! Great price! |
Posted on: 2006/1/19 6:04
Ramrod | RE:'96 rear brakes | ||
While I was in there changing the brakes I removed the inner fenders/wheel wells, replaced the shocks, and checked for loose, broken parts. I also cleaned and painted the fender wells black and made a big diffrence in appearance.
Posted on: 2008/1/29 4:19
