224 user(s) are online (158 user(s) are browsing Forums)
Also known as the DIC.
kelley cleaning
thomasville ga
122 Posts
how do you clean and stop the oxidation of the altenator and waterpump front cover? opened hood and white powder all over the aluminum..thanks .
Posted on: 2009/4/5 12:08
Durango_Boy Re: cleaning
kelley wrote:
how do you clean and stop the oxidation of the alternator and waterpump front cover? opened hood and white powder all over the aluminum..thanks .
Ironically the white reaction is a protective barrier that forms on the aluminum that protects it from actually being damaged by the elements.
The best way I have found to protect aluminum, both polished and raw, is to use off the shelf Turtle Wax. It's a barrier that you can apply a few times a year to keep that white residue down and keep your alternator looking fresh.
The BEST way to do it is paint it. Find a nice cast coat iron color or metal gray you like and paint the alternator case.
Posted on: 2009/4/5 13:55
