ianh | constant fan | ||
hi all.New to the site.Have an 88' coupe, in the UK. Lovely though she is, the electric fan stays on constantly. She sits at around 180 degrees. I've been told that some a/m chips cause this. You guys would know, so I'm asking!!
My main concern is that the fan motor will burn out.... |
Posted on: 2007/1/26 12:11
Ian Harris 88´ Corvette 03´ ZRX 1200 |
Alcee1 | RE:constant fan | ||
Do the fan come on when you first start the car, or does it come on when the temp hits a certain degree?
Posted on: 2007/1/26 15:45
Edlebrock Heads, 2030 cam, X-ram w/EGR, 1.6 R/R, Bored TB´s, AFPR, Pro-built Tranny, Vigilantly 2600, Transgo, Dana 44 3.54, Hardened Pushrods & Head Bolts, Custom performance chip, K&N, Double roller timing chain, Aluminum radiator & flex hose, MS |
ianh | RE:constant fan | ||
hiya. it comes on and off with the engine.
Posted on: 2007/1/27 17:26
If your saying what I think your saying, then it sounds like your fan is hard wired and not wired to the temp switch
Posted on: 2007/1/28 3:01
