kelley | antenna relay | ||
found 2orange wires corroded off the antenna relay on the 94 vert.i assume they both go to the same terminal,,,but the conector is corroded ,can just one be replaced or do i need to get a new base unit? thanks,,,
Posted on: 2009/6/7 13:26
bogus | Re: antenna relay | ||
if they are that corroded, I would get new parts.
I am just not sure what a "base unit" is. Are you referring to the harness connector? If so, get a new one. Also, inspect the rest of the wiring in that area for additional corrosion issues. If it has happened once, it more than likely will happen again. |
Posted on: 2009/6/7 17:07
kelley | Re: antenna relay | ||
yes the conector, who would have one? and the wires are live what do they run? my 94 manual says look in the 93 book for all audio info,,,,duh,, guess i missed that part when i got my books,oh well thanks for the help...
Posted on: 2009/6/8 22:02
