167 user(s) are online (108 user(s) are browsing Forums)
Notorious PeteK, here's a WTF for you!
A couple of months ago I installed a built 4L60E in my '95 and also at that time, reinstalled my 3000 Vigilante for the first time in about a year or so. All's been well until today when I took the first trip on the interstate with it in a couple of weeks. It was only a short trip, about 10 miles, to visit my new employer that I'm going to work for soon. Anyhow, it wouldn't go into converter lock-up either there or on the return trip. However, once I got back on the two-lane for the last few miles before home, it kicked in fine at 45-46 MPH where it normally does. On this curvy road, I'm unable to get much over 55 for long but it went in and stayed in as it should. I haven't checked for codes yet, it's just too freakin' cold here to go out in the garage tonight! But I will check that Saturday. I just wondered if anything might jump out at you as to why it would work at slower speeds but not at 70 or so. Thanks.
Posted on: 2008/1/3 23:37
PeteK Re: PeteK, here's a WTF for you!
Before you do anything, give vigilante a call. It is possible that the converter needs more line pressure to allow lock up. I seem to remember twisted having a similar problem.
Posted on: 2008/1/4 1:37
