526 user(s) are online (60 user(s) are browsing Forums)
Schrade Will tech 1A test my RPM Needle Circuit???
My RPM needle had a good 'sweep' motion before I did resto on the I/C. Now it's 'jerky'. I think the DE Grease might have impeded (pun intended Resized Image the signal / circuit somewhere....................
Posted on: 2016/2/21 1:34
Matatk Re: Will tech 1A test my RPM Needle Circuit???
22996 Posts
I can't say offhand. The FSM should say? Does the needle self test when you turn on the car?
Posted on: 2016/2/21 18:21
bogus Re: Will tech 1A test my RPM Needle Circuit???
I'm with Matt on this one... What does the FSM say?
I know it can do a lot, tho... And there are some tests that can be done with the CCM directly.
Also, with the needle, make sure there isn't any mechanical interference...
Posted on: 2016/2/21 21:52
Schrade Re: Will tech 1A test my RPM Needle Circuit???
DUH. Check GM FSM, to see if GM Scanner will do the test.
(that is, IF Techline Tech 1A is same as Vetronix Tech 1 A)
Posted on: 2016/2/21 22:01
Considering that Vetronix is calling their machine the Tech 1 A... I would HOPE it does the same tests...
Posted on: 2016/2/22 18:49
No, it will NOT test RPM function.
Special tool needed J-33431 Signal Generator.
But there IS good news; Techline is a diagnostic tool referred to on same page...
jpg  IMG_8297.JPG (867.52 KB)
1687_56cde25b782fd.jpg 1698X2264 px
Posted on: 2016/2/24 17:03
22996 Posts
Too bad you're not closer.
Posted on: 2016/2/24 21:48
