120 user(s) are online (83 user(s) are browsing Forums)
Early SBC
4.3L 265ci - 1955 thru 1956
4.6L 283ci - 1957 thru 1962
4.9L 302ci - ...
damien89 89 vette misfires when at operating temperature
53 Posts
Hi, my 89 vette misfires when it reaches above 160'f +, it does it randomnly but it always does it, if i turn off the engine and restart it it works fine then after a few seconds it starts misfiring again. When it misfires the fuel pressure drops and if i give it a bit of throttle it jumps between 10-50 psi erratically, i was going to change the fuel pump but when its cold it works just fine, 40psi at idle and 47psi with load.
Anyone have any tips what should i check?
Posted on: 2019/10/27 9:24
Matatk Re: 89 vette misfires when at operating temperature
22996 Posts
I'd say you're on the right track. Fuel pumps are known to fail and show the symptoms when they get warm. The erratic fuel pressure is a sign of that. I'd replace the pump and report back.
Posted on: 2019/10/27 14:32
