pappyfreebird | lower body side panels | ||
on both side of my rig the lower strip is missing the last screw on each side right in front of rear tire (cause it to hang a lil) question is : is there a nut er somthin in that lil humped part??? like i see id hafta pull inner fender well n then run a skeeroo down that way...but is there a nut or whats the way to bolt her back up ???? thanks pappy
Posted on: 2008/5/1 21:39
CentralCoaster | Re: lower body side panels | ||
I've removed those, I think I had to remove the rear fender liner partway to get to that screw. And even then you'll need a 1/4" drive with a wobbly or ujoint.
I think they're 8mm, its sort of hidden in a pocket back there. |
Posted on: 2008/5/1 21:46
pappyfreebird | Re: lower body side panels | ||
thanks cc...so there is a built in nut of some sort in the lower panel?
Posted on: 2008/5/1 22:30
ok that lil bump in there is simply a solid spot fer a skeeroo to thread into heyhuh,,,well thanks again ill hafta smoosh my hand in there this wkend n git er done
Posted on: 2008/5/2 11:53
1Fast04Vert | Re: lower body side panels | ||
If you mean the rocker panels under the doors they use what is known as a 'bathtub insert' and a small screw to secure the lower edge of the rocker panel to the frame. They are available about any auto parts store, look in the 'help' section.
Posted on: 2008/5/2 12:54
well got my rocker panels snugged up in rear... maybe mines different cause it was simply a thinker spot molded in n took a skeerrooo just like the fender wells etc....
Posted on: 2008/5/3 22:39
